A few radios I have completed
Once it got warm here in Alberta I got working on these cabinets.
         I did the chassis during the winter and finally got these ones done.
Zenith 7S363
 Deforest Crosley  Ritz 9rR1092
 Rogers 10-65
RCA  810K
 Deforest Crosley 7R931
  The 10-65 [with legs] had no legs when I bought it,so I bought a highboy cabinet just for the legs.
I cut several pairs of legs, in case I need them
  I still have four more in the garage to get done this year.
Enjoy the photos guys.
 Dan in Calgary
   Living in Calgary Alberta
Beautiful sets. Am I understand you did all of these cabinets in recent months? Impressive!
Very Nice!
Icon_clap Icon_clap Icon_clap
Excellent work ! Icon_clap
Yes  I did  all  the cabinets this spring . I started about the first week in May.  I have to get them done while the weather is warm.
  Once I have everything set up it is not too bad..
 The hardest part is stripping as it does take a long time,but you have to get'' ALL'' of the old finish off.
       The best part is when the final coats of lacquer go on
Here is one more that I just completed. it is a Rogers Majestic model 7M621
 Dan in Calgary
Beautiful work, Dan. Do you work on multiple cabinets at once or one at a time?
Excellent work Dan Icon_smile
I start with one and after it is stripped and stained, I start on another one while the stain is drying.
I let it dry overnight.
 I usually have a couple on the go at one time.
 Dan in Calgary
Dan
Great job! Very good-looking sets.
Beautiful work, Dan! Take care and BE HEALTHY! Gary
