41-285 output transformer low ohms ??
my readings are 148.4 ohms and 171.6 ohms and a black to white 320 ohms the manual says 170 and 190
are my readings to low to work i have a load hum,when i inject a signal at the antenna it's loud and clear with hum
thanks
john
Seems like your transformer is OK. The tipical problem is they go open. I think your only problem is hummmmm. If you remove the 7C6 tube does it still hum?
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 4747 online users. [Complete List]
» 2 Member(s) | 4745 Guest(s)
