Threads: 43
City: Chicago, IL
Time to tackle the H-3 speaker with open field coil.
[Image: https://live.staticflickr.com/65535/5168...ae3e_c.jpg]
The cone came out much easier than I expected
After removing the screws around the rim, I just needed a little persuasion with a razor blade around each screw hole. No acetone require. I'm not sure if the re was no glue or it had failed over the years.
The only tricky part was the spider. There I did use a few drops of acetone and a small plastic pry bar to loosen it up.
[Image: https://live.staticflickr.com/65535/5168...1639_c.jpg]
Now, I just need to whack this out. Wish me luck.
[Image: https://live.staticflickr.com/65535/5168...61d9_c.jpg]\
Threads: 43
City: Chicago, IL
Well this setup is getting me nowhere. Should I be whacking it from the other side?
[Image: https://live.staticflickr.com/65535/5168...ca6a_c.jpg]
Threads: 43
City: Chicago, IL
Ah-ha. This thread set me straight. https://philcoradio.com/phorum/showthread.php?tid=3938
I'll check with some local machine shops.
Threads: 43
City: Chicago, IL
Threads: 43
City: Chicago, IL
Perhaps a gear puller would work ?
Threads: 72
City: Linn Creek, MO
It takes a mighty force to push that pole out, I don't think a gear puller will do it. A few years ago I rewound one of these K speaker field coils. I made a hydraulic press using a 12 ton bottle jack and 4x4 wood pieces for the frame.
M R Radios C M Tubes
Threads: 72
I found the thread about that speaker Philco 70 Cathedral Speaker (philcoradio.com) There are a couple of photos of the press.
Threads: 43
City: Chicago, IL
Oof, I see what you mean. Thanks for the link and photos.
Did you use the same jig to reinsert the pole ?
(This post was last modified: 11-19-2021, 02:12 PM by Bob Andersen.)
Threads: 72
Yes, reassembly is just the reverse process. Notice the portion of the pole that presses into the frame is much smaller than the rest of the pole. This creates a large shoulder, that when pressed back in tight to the frame, will perfectly center the pole.
(This post was last modified: 11-19-2021, 05:27 PM by Steve Davis.)
Threads: 112
City: Medford OR (OR what?)
I use my log splitter. It has a 38-ton ram. Very easy. You can use a large socket to support the frame as you push the pole out.
(This post was last modified: 11-20-2021, 12:06 PM by Phlogiston.)
Threads: 113
City: Omak
State, Province, Country: WA
Hello bob,
luckily you got that far !
nice Job so far and Russ that is using your brain a Log splitter who would think of that !
Threads: 3
City: Drexel Hill
State, Province, Country: PA
Hi Bob...been following the YouTube series with great interest. I have the middle of the production run model 90 chassis with the single 47 in a lowboy cabinet that I restored to like new condition. I'm an electronics novice having restored 4 1903s-1940s Philco radios. You and shango66 have been my inspiration. I have followed your 90 restoration step by step and have run into some difficulty. For now...just a hello! It's a thrill to find you on a message board!
Threads: 43
City: Chicago, IL
Hi. Whenever I work on a Philco, I post here along with making videos. This Phorum is an invaluable resource and I'm grateful for the support and knowledge I've received.
As for the speaker, I plan on picking up a 6-ton shop press. Probably from Harbor Freight if I can find one in stock in my area.
Basically, the same as the jig Steve put together. I'm sure I'll find other uses for it to justify the investment.
https://www.harborfreight.com/6-ton-a-fr...-1666.html
Threads: 3
City: Drexel Hill
I loved your little explosion and chuckle this morning..."POOF...whoa....heh heh!"
Threads: 43
City: Chicago, IL
I spent Black Friday morning driving to several Harbor Freight locations only to learn that there are no presses within 100 miles. Also, they would not sell me the floor model and had no date when they might restock.
Well, I wasn't going to drop $140 to have one shipped to me so I went back to plan A and got a bigger hammer.
I also heated the frame with a propane torch. With the frame supported by a couple strategically placed concrete pavers I went to work.
I used some sacrificial metric sockets carefully centered. The first few hits didn't do much. The pole appeared to be mushroomed - either when it was made or from my earlier attempts.
I was about to give up when I realized the pole had moved a tiny bit. That encouraged me to whack it even harder and finally it got passed the mushroomed end. Then it was just a couple light taps to get it fully out.
The pole seemed about as hot as the frame so I'm not sure it made any difference. However, when I go to reassemble, I will put the pole in the freezer and heat the frame.
Not exactly how I thought I'd be spending my day off, but I'm glad it's done
[Image: https://live.staticflickr.com/65535/5170...24a0_c.jpg]
(This post was last modified: 11-26-2021, 10:31 PM by Bob Andersen.)
Users browsing this thread: 37 Guest(s)
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM |
91H Code 126 Restore
I'm pretty sure that the dotted line I circled in an earlier post signifies that it is applicable to the 226 model which...RealRider — 08:05 AM |
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
There are currently 4407 online users. [Complete List] » 4 Member(s) | 4403 Guest(s)
