Better Source For Solen Caps
Threads: 14
City: Irvington, NY
Recently I needed a set of polypropylene film filter caps for a vintage communications receiver restoration. Have been buying the Solens from AES in the past, but now found a better place to buy them.
Tube Depot is selling the same Solens considerably cheaper ( $7.95 for a 15 uF, 630V vs $10.45 from AES) plus their shipping charges are also much less.
https://tubedepot.com/t/diy-central/capacitors
At these prices it makes sense to use these rather than electrolytics if you have the room, especially for the first cap right after the rectifier. Nice to know you will never need to replace the filter cap again.
Hey Mondial! How are you? Long time no hear.
Thank you for this link. Lower prices for the same product is always better.  Plus they carry 6.8 uF Solens, which would be good replacements for the 6 uF electrolytics used in 1931 Philcos such as the 70, 90, and late 112 plus easier to fit into the original Mershon or Sprague electrolytic cans.
Threads: 114
City: Sneedville, TN
 Thanks for the heads up ! It's amazing how much condensers have progressed in even the last 20 years !
Threads: 569
Wow, good $1.50 to $2 difference with AES (this is where I got mine).
I probably should stock up.
Most useful are the 8.2uF and 6.8uF.
Threads: 113
City: Omak
State, Province, Country: WA
Hello Mondial,
Sweet thank you for letting m know and yes my Zenith 908 that i replaced the capacitors in I film type .
yes I agree in the long run it makes sense if you have the room .
my next Philco my 38-10t I will for sure use film type.
Threads: 112
City: Medford OR (OR what?)
Isn't Tube Depot and AES at the same location?
I bought a bunch of these on sale a few years ago.
I have looked for similar caps at Mouser. Never found anything that didn't cost a ton $.
Threads: 569
All axial caps with these parameters are non-stock in Mouser.
AES is in Tempe, AZ; Tube Depot is in Memphis, TN.
https://tubedepot.com/pages/contact-us
Russ, you may be thinking of Amplified Parts which is the same outfit as AES. Plus, they may also go by another name as well.
Mike - Mouser's radial caps in large values such as what we need for electrolytic replacement in vintage radios are not cheap either, as Russ said. I used some film radials to replace 1 and 2 uF paper caps in my Philco 87 and 65 radios, and they weren't exactly cheap.
Threads: 14
City: Irvington, NY
Hi Ron,
Yes its been a while. Have been away from Philcos for a few years while my interests went toward vintage ham radio gear. Checked in occasionally but haven't posted.
Was reading the posting regarding the 86 restoration where Radioroslyn suggested the film cap filters and remembered where I got them last. Thought you guys might find the link useful
Greetings to all the crew!
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
