Simplex Radio - Speaker
I have found an old, 1932-34, Simplex cathedral radio. Simplex was based in Sanduskey Ohio and was bought by Philco in 1937 I believe. The most obvious issue is that it does not have a speaker. I understand that the speakers of this era have both a field coil and a voice coil. Will a Philco speaker from the same vintage work? Are such available? I have a schematic of the Simplex. I have heard of some modern workarounds, but I think I would prefer to get an old replacement if it would work. Any thoughts?
Thanks
I realize this is a prehistoric post but I've come across a few Simplex set myself. So if you(wahook) are still are around I'd like to chat. I found this post looking for some Simplex ad info on Google.
Tnx
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 3215 online users. [Complete List]
» 2 Member(s) | 3213 Guest(s)
