Philco 6672N Pwr Transf.
I have the 6672N transformer. I can only find the 6672 diagrams on the schematic for the model 15. I can't find a diagram for the 6672N-it doesn't quite jive with the layout of the 6672N and I would like to power it up for testing. Can someone point me in the direction of the wiring diagram for my 6672N? Or are they the same? Thanks.
Hi Wilbur,
6672-N is the same as part no. 6672. The letter suffix indicated the actual manufacturer of the transformer or choke. "J" stood for Jefferson Transformer Corp. I do not know what "N" stood for.
Here is a drawing of the transformer connections:
Notice the wire which is identified as terminal 4. Notice also in your photo how that wire connects to terminal 9 which is correct.
From the model 15 service data, a chart identifying the terminals:
I hope this helps.
Ron
Ron, yes, thank you. I just variac tested my transformer and all the windings check out OK.
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
Here we are. Boomer Sooner!  :lol: jrblasde — 09:40 PM
