RESTORATION MODEL 57C
I have restored a 57C. The primary of the oscillator was cut off.
Who may be interested:
22 turns. 39 gauge.
Regards and good year 2022
Bet that was a job scraping it down to connect, kudos...
I use a nail file to scrape the enamel off the magnet wire. I place the wire on the nail file and my finger on top of the wire then I drag the nail file across the wire very carefully without much pressure on the wire a few times. I have tried burning it off with a lighter and it breaks the wire.
-Carlos
One can do the same thing using a small, folded over piece of 400 grit sandpaper Again, you don't want to use much pressure.
Thanks, everyone! I suppose I’ll keep these installed since I have them and they do fit. But moving forward I’ll know th...jrblasde — 07:57 AM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
There are currently 3391 online users. [Complete List]
» 2 Member(s) | 3389 Guest(s)
