Electromagnetic Speaker Repair
I have a small table radio with electro-dynamic speaker. Due to oscillations and motorboating early in the repair process, the speaker was damaged. It shows no visual signs, just rattling. I notice if I put my finger lightly on the small of the cone, the rattling stops--leaving me to think there must be a way to repair this without reconing. I was thinking about dropping a smidgen of rubber cement in the center of the cone. That would be too permanent should it not work. I need some ideas from those experienced! Much appreciated!! Thx.
Hmmm. Before you try the rubber cement take a look at the speaker repair entries that were made by other collectors here in this web site. I have found them to be VERY helpful.
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 4721 online users. [Complete List]
» 1 Member(s) | 4720 Guest(s)
