Size fuse for line in for Philco 48-1270
Greetings! I restored a Philco 48-1270 a while back and added a fuse to the line in just before the terminal block. I used a 1.5 A fast-blo and that held up fine until recently. I switched on the set first thing in morning and it blew in the first second. I can’t find anything wrong with her. Working fine right now. Do you think 1.5 A is a bit too small for the startup? She’s rated at 140W which I believe may be steady state. Anyway would appreciate some voices of experience.
Try a slow-blo before raising the amps.
That’s a good idea. I was concerned about going up. Gonna order some right now. Thanks!
+1 what David said. Current draw on start up is highest as the tubes warm up. Slow blo fuse should be enough. Take care and BE HEALTHY! Gary
Hello Bigreddog,
Yes, I almost always use a slow blow as the rest said that first inrush of current when those tubes are cold is where the current is the most like when you first turn on a lightbulb !
Thanks all. I know it’s a small thing but I am bad about sweating the small stuff. I guess that’s why I put the fuse in there to begin with. Happy Easter!
I wouldn't consider a fuse added as "bad about sweating the small stuff". Always try to err on the side of safety; it usually wont do you wrong. Take care and BE HEALTHY! Gary
Put the slow blow 1.6 A fuse in this morning and she is singing again!
The other choice, which I have installed in my 53-1750 is an Inrush Capacitor along with a regular fuse.
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
