37-116 odd noise/distortion
Now, On start up i get a "blurp" sound (say it out loud---thats it)  after about 5 seconds and then the radio warms up and plays after about 15-20 seconds. I am also starting to get some distortion at the higher sound frequency's. (singing)  This has been hit and miss and less the longer the radio is on.
All this is new in the last 2 weeks.  The radio was recapped/resistored about 3 years ago by someone known to me to be reputable.  I play it about an hour every day.  I can hear something is going on, changing in the sound.  Yes this is AM radio and my reception varies greatly day to day but this is beyond that.
Since i believe the caps are ok and it does play well other that this occasional  higher frequency distortion/blurp, i am thinking a tube going bad?
I dont have a tube tester.  All heaters are on, but i do have a few metal tubes.  They are warm,  not hot.
Start on the  Rf and Audio section?
http://www.nostalgiaair.org/Resources/199/M0013199.htm
Thanks
Bill
Hi Bill, you are correct in focusing on a bad tube. I would change the 6J5 second detector tube first. But don't rule out a phlaky tube pin connection.
I took the 6J5 out ( its a metal one), cleaned the pins and cleaned the socket with contact cleaner and a airbrush brush i got at harbor freight. Put the tube in/out 3 times wiggling it each time. Fired up the radio and no "blurp" and no distortion. I will try again tomorrow as the "blurp" was only on cold tubes, but....
Thank you! Good call!
Bill
It's been a few days and the "blurp" has gone away, but while i was spending time in the back of the set i noticed this.
This is one of the 6b4g power tubes, they were purchased as NOS set about 2 months ago. You are looking at the right tube and the left one is in the frame.  I know it is dark but i wanted to capture this blue/purple glow.  It is about this bright with normal ambient light.
What is happening?  I switched the tubes and the glow follows the tube and not the circuit.  I have 2 heater circuits one with about 6.1 volts and one with about 6.6. You can see at the end of the vid that a small area stays blue once the tube warms up, but  it is not evident in the other tube.
I use a fake name for youtube.
Thanks
Bill
 [Video: https://youtu.be/llSyscjRO4A]
My thought would be that the tube has become gassy, air leaked into the tube.
See:
https://philcoradio.com/phorum/showthrea...1#pid87101 and
https://www.russoldradios.com/blog/previous/10 and
https://philcoradio.com/phorum/showthrea...ight=gassy
What symptoms would i be looking for as/if it gets worse? The getter is not white but light grey.
Thanks
Bill
Why wait? Change it.
Also, if you have a tester, a good one, they test for gas.
i dont have a tester but i do have an old spare. What are the downsides of leaving it in? Of course anything is possible, but most likely bad things that could happen? I guess just trying to understand the failure...sure sound would suffer , have to replace but until then... is this a likely transformer ending event kind of thing/or...? Again, just trying to understand what is going on here.
Thanks
Bill
Well, it might be an engineer in me talking, but the downside of leaving a faulty part in a device is exactly it - there is a faulty part in the device, and Gosh only knows what it might do and in what way it will fail (it will) and what the consequences might be.
One thing is a weak tube: it is a natural thing, it works worse than a good tube but it is safe and simply is not performing as good as it should. A gassy tube has a timebomb in it.
That's my question...what's the timebomb? What does a gassy tube do to the set on failure? Just trying to understand here.
Bill
Gassy tube could develop large leakage and simply short something, or overload. Gas basically creates the conductivity where there shouldn't be any. Thus changing bias in unpredictable way.
Here's one account.
https://rec.audio.tubes.narkive.com/hPon...mode-gassy
Ok i get it. I pulled the tube and for now replaced with an older one. Talked to the seller and he will replace the gassy tube.
Thanks
Bil
For the cost of a tube even a not so usual tube
worth doing.
Good luck.
OK, so, now you know why those of us who get into restoring antique radios buy a decent period tube tester. You will want one which tests all the early sizes, 4, 5, 6, and 7 pin base, as well as octal and locktal base at a minimum. They can be found on eBay. They are not as cheap as they once were, but are still worth the money if you really get into this hobby. Once you get one, replace any paper and electrolytic condensers in it.
600A Hickok to me has the best price/performance ratio.
Of course 539 is better, and then there are some better still, but 600A will do most, if not all, that you need for restoring radios.
The donor chassis looks pretty good, based on the photo I saw.jrblasde — 08:43 AM
Is the chassis in the parts set less rusty then the one you have been working on or about the same?Arran — 02:50 AM
Gloritone 27 Radio
Hi Dconant, Yeah, I think someone tried to combine the 2 functions.  I don't think it will work.  In the early 27 sch...MrFixr55 — 12:04 AM
Gloritone 27 Radio
Well, now you ask that question and there we are, the time travellers.morzh — 11:44 PM
Gloritone 27 Radio
That's OK, Morzh, I do that all the time. If we could catalogue the answers to questions that no one asked, when they d...MrFixr55 — 11:35 PM
Today the 10 Ohms resistors came (It might've meant in the sch it was 10 ohm total), and soldering them in improved thin...morzh — 09:33 PM
Gloritone 27 Radio
Oops, sorry. I've answered a question no one asked. :)morzh — 02:13 PM
Gloritone 27 Radio
To clear things up a bit. The Philco pot (33-5040) is single gang 3 terminals with AC switch. The picture shows how my p...dconant — 01:52 PM
Gloritone 27 Radio
The 20 pot has two sections: one is the Antenna attenuator, the other is the cathode bias one.morzh — 12:11 PM
Gloritone 27 Radio
Does the Philco pot have only 1 element (2 or 3 terminals) or is it ganged (5 or 6 terminals)? You state that one con...MrFixr55 — 11:52 AM
There are currently 3728 online users. [Complete List]
» 2 Member(s) | 3726 Guest(s)
