Threads: 32
City: Nipomo
State, Province, Country: CA
Hi everyone,
I have a Philco 52-944 that I recently re-capped and can’t get a signal out of it. Hopefully someone can give me a tip as to what I’m missing. I may hear a faint crackle or hum in the speaker but no radio signal coming thru. I have checked everything that I could think of, tubes, transformers, tuner, I retraced the schematic, checked continuity throughout the band selector. I even have a 53-958 that I compared wiring. Now here’s the big clue, I replaced the selenium rectifier with a diode and adjusted the following resistor to get the 130v (not what I expected, 15ohm gave me 132v), the 120v called for at the 70mf electrolytic was 116v, but then the voltage at the 3rd electrolytic was only about 40v and the preceding 470 ohm resistor gets blistering hot.
Can you help lead me in some direction?
Alan
Threads: 113
City: Omak
State, Province, Country: WA
Hello Alan,
First all that radio looks great so far !
So C38B 40ufd capacitor ?
What i would do with no power applied is to take some resistance readings to make sure there is no shorts and check every tube again it sounds like Audio amp section could where the issue lays it looks like you replaced a lot of resistors and Mica capacitors double check and triple check everything .
Threads: 32
City: Nipomo
Thanks Richard, the 470 ohm resistor will burn if I don't shut it down. There's a lot of bad or no voltage readings that I don't understand. I think at one point I fed an audio signal into it and got it clear so I don't think the problem is in the output section. What would cause that resistor to burn?
Alan
Threads: 113
City: Omak
Hello AlaN,
Excessive current draw will cause that resistor to get really hot !
One the first things that I would do is to take a resistance reading but make sure you have no power applied measure the resistance from R26 and C38B junction also check all of your wires go through the schematic and look at everything that is feed from C38B one by one check everything!
Threads: 50
City: Shenandoah,
Hi Alan, just a thought here. If originally the 470 ohm resistor wasn’t burned, then possibly the new 40mfd cap C38b could be bad or you have the + and - reversed, that would surely load down the 110V B+ and overheat that resistor.
Ron
Bendix 0626. RCA 8BX5. RCA T64
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
(This post was last modified: 08-01-2022, 08:02 AM by 462ron.)
Threads: 32
City: Nipomo
Thanks Ron, I have checked polarity, but I hadn't thought about swapping out that electrolytic. I'll give it a try. Then I guess I better trace out the schematic, again.
Alan
Threads: 113
City: Omak
Hello Alan,
That is a good idea what Ron pointed out !
Threads: 32
City: Nipomo
Swapped out the 38B 40mfd electolytic and the diode too, no change. In process retracing the schematic.
Alan
Threads: 44
City: Roseville, MN
Hi Alan,
Check the hot 470 ohm resistor on AM and FM. The 110 volts DC is feeding FM plate circuits as well as audio screens so maybe if it doesn't get hot when AM is selected you can eliminate some circuitry.
Threads: 32
City: Nipomo
Thanks, haven't thought of that. On AM band I just watched the 470 ohm, 2 watt resistor fade color then the casing began to melt. Not sure about the FM, but I can scratch out any FM circuitry that is isolated by the band selector and reduce the circuitry to look at.
I'm starting to get a feeling about the IF transformers. My trouble started when I damaged Z1 and got a replacement from another radio. Finding the radio dead I replaced Z2 so I had a pair from the loaner 51-934. Their terminals have green and pink dots that don't always agree with the schematic, even one that I never removed. I get good ohm readings so the transformers are probably good, but there may be a wiring problem there. I get a headache if I stare at these too long.
Alan
Threads: 113
City: Omak
Hello Alan,
I think you may have found your area where the problem lays !
Gloritone 27 Radio
Hi Dconant,
Yeah, I think someone tried to combine the 2 functions. I don't think it will work. In the early 27 sch...MrFixr55 — 12:04 AM |
Gloritone 27 Radio
Well, now you ask that question and there we are, the time travellers.morzh — 11:44 PM |
Gloritone 27 Radio
That's OK, Morzh, I do that all the time. If we could catalogue the answers to questions that no one asked, when they d...MrFixr55 — 11:35 PM |
Today the 10 Ohms resistors came (It might've meant in the sch it was 10 ohm total), and soldering them in improved thin...morzh — 09:33 PM |
Gloritone 27 Radio
Oops, sorry. I've answered a question no one asked. :)morzh — 02:13 PM |
Gloritone 27 Radio
To clear things up a bit. The Philco pot (33-5040) is single gang 3 terminals with AC switch. The picture shows how my p...dconant — 01:52 PM |
Gloritone 27 Radio
The 20 pot has two sections: one is the Antenna attenuator, the other is the cathode bias one.morzh — 12:11 PM |
Gloritone 27 Radio
Does the Philco pot have only 1 element (2 or 3 terminals) or is it ganged (5 or 6 terminals)?
You state that one con...MrFixr55 — 11:52 AM |
Gloritone 27 Radio
Yep. It is a light version of Philco 20.
I guess it was soon after the 24 tube appeared on the market and everyone start...morzh — 11:04 AM |
Gloritone 27 Radio
Hello guys,
Well i just looked at my Gloritone and low and behold it is a model 27 !!
Yes, Mr Fixr55 I have couple Sea...radiorich — 10:54 AM |
