BC221 -Q frequency meter manual
Hi everyone, A friend gifted me a beautifully restored WW2 frequency meter type BC221 complete with tables but I do not have a manual for it.Is the manual for this available anywhere on line? I'd be grateful if anyone can point me in the right direction here.Thank you and Cheers
web page info at the bottom of the page is link to download the TM for the BC221  https://www.radionerds.com/index.php/BC-221
Thanks heaps David.That is exactly what I wanted and more.Great service. Cheers,David
