Model 38-17, Code 121 schematic
I've recently acquired a nearly perfect Model 38-17. The chassis is clean and the wood case is nearly perfect. I've noted that there is no listing of the 38-17 in Nostalgia Air or in Ron's "Philco Radio 1928-1942" bible. I believe electrically this is a 38-15.
I'm in the process of replacing caps and out-of-tolerance resistors and have run into a minor problem. The 38-15 schematic has both detector diodes connected together. My 38-17 has them separated with one dedicated to developing the AVC signal. From other schematics, I can guess the resistor and capacitor values for the AVC circuit but I would like to get the actual schematic, if possible.
Any suggestions for obtaining a schematic that matches my radio?
Thanks for your help.
Don
The schematic can be found here:
https://www.radiomuseum.org/r/philco_38_17t38_1.html
The RM schematic is the 38-15 schematic.
I don't recall ever seeing a 38-17 schematic or service bulletin. As you stated, the 38-15 is basically the same.
You will find better info here, and higher resolution, than that found at RM - and you don't have to pay for it, either.
https://philcoradio.com/library/download...%20291.pdf
The same change in the 2nd detector circuit you described was also made to later production models of the 38-15. That change is described on page 22 of the Philco Changes in Models document, which you may download here:
https://philcoradio.com/phorum/attachment.php?aid=799
Again, what Radiomuseum has is the 38-15 schematic. Look at it closely, at the bottom. It clearly states, "Fig. 4 - Schematic Diagram, Model 38-15 (emphasis mine).
I even went to the trouble of downloading it - look closely at the bottom of the picture below:
Thank you Ron, based on what I see on my 38-17, I concluded that the 38-10 schematic matched my radio for the 75 detector circuit. Your reference to page 22 of the Philco Changes in Models document confirms this.
As always, you guys are great at pointing us less experienced in the right direction.
Don
Morning, Ron! Yep, that’s the Moyer I spoke with. They did say that they researched for any off-brand equivalents but di...jrblasde — 08:51 AM
Joseph, the Moyer Electronics I’m familiar with is in Pottsville, PA. Only a half hour from me. My dad used to to buy fr...462ron — 08:24 AM
Thanks, everyone! I suppose I’ll keep these installed since I have them and they do fit. But moving forward I’ll know th...jrblasde — 07:57 AM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
There are currently 3270 online users. [Complete List]
» 1 Member(s) | 3269 Guest(s)
