Philco 51-930 dial pointer what lubricant to use
Hello Everyone,
I am back working on my Philco model 51-930 My big question of the Day is what type of grease should I use to lubricate the area where the pointer scale rides alone as you can see in the photo below .
my first thought was white lithium and the other grease that i have on hand is super lube and last is good old Phone lube.
So what is your thoughts ?
i would try paste wax or silicone spray applied with a brush. grease will dry out and attract dirt. or nothing at all. is there a problem? pioneer receivers of the 70's used a plastic "shoe'' inside the pointer cavity. the dimples are the only contact areas and shouldnt develop much friction
Hello falcon,
there was grease but I cleaned it off it was a mess and gumming up the dial pointer .
have you tried it dry?
I use a very thin coat of silicone grease. Squeeze a dab on the end of a finger then wipe around the edge.
I've had good luck cleaning it really really well, then polishing the point of contact with 00 steel wool and a dremel to an almost mirror shine. Smooth as butter after that.
Hello Guys,
Thank you for your input !
P.S. I can get back to working on this set since my resistor that I needed came in today !
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
Philco 91 Restore Code ??
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet i...morzh — 02:58 PM
The width does not get narrower with generator. I think I will try some other cap values.dconant — 02:56 PM
410pF is a large capacitance to parallel to a compensator. As for the shadowmeter....yes, 3/8" is a bit wide, bu...morzh — 02:49 PM
My new nostalgic video... My weekly video on radio history Who is interested - come, watch, critically evaluate the qu...RadioSvit — 01:47 PM
The shadow meter in the radio is responding to tuned signals but it never goes to a very small shadow even on strong sig...dconant — 01:01 PM
91H Code 126 Restore
Hi Nick, I am finishing up a 91 code 121 (one speaker). The dashed line is for the code 221 (2 speaker) set. I see there...dconant — 11:17 AM
Joseph, Yes, Rich is right, they are just fine to be left in there. Also, what I do when I re-stuff these specific o...morzh — 09:41 AM
Hello Joseph, I would leave them they are just fine ! Man Moyer Electronics brings back old memories I did not know th...radiorich — 09:33 AM
Rich Those are exact same I used before. I just recently bought these from Mouser. DE2E3SA103MN7AT02F It is exac...morzh — 09:16 AM
There are currently 4015 online users. [Complete List]
» 3 Member(s) | 4012 Guest(s)
