Veneer Where do I buy it?
I'm restoring a 37-610, I'm trying to reveneer the front need a piece 21"X17" Walnut, it is not available in my aeria[This is my first try at veneering] , Where is a good place to order it?
One suggestion: Constantine's.
http://www.constantines.com/veneer.aspx
There are other sources; a Google search will reveal more vendors.
I have bought veneer from this fellow on several occasions http://shop.ebay.com/skitts1/m.html?_nkw...m=&_ipg=25
M R Radios   C M Tubes
There are currently 8543 online users. [Complete List]
» 1 Member(s) | 8542 Guest(s)
