Philco 40-88 chassis wiring pictures
I could really use a picture of the chassis wiring for a 40-88. I’m having difficulty reading the schematic and I didn’t take pictures when I began replacing bare wires and especially from the on/off volume pot. Any reference pics or info would be appreciated.
Wicker Bill
This might have a clearer schematic:
https://worldradiohistory.com/Beitman-Manual.htm
Download the check mark for 1940 then scroll to page 80.
Or
I think they all come from the same place...
The power switch is pretty standard fair for a battery set. It disconnects the A+ and the B+. This insures no battery drain when the set is off.
Thanks, I was able to get a better schematic.
Mark
Eico 232 VTVM Schematic
There are currently 8997 online users. [Complete List]
» 1 Member(s) | 8996 Guest(s)
