3D Printed Parts...
I was missing the original electro Caps and the clamp for the 630B tombstone I have, and thought it would be a good job for my 3D printer. Also I made some tubes the same size as the tubular caps in the radio and printed some labels for them too.
Nice work!  I think 3D printing will become a real positive source for replacement parts not otherwise available.  I used a service (you send them the design and they send you the part) to create a bezel to replace a warped tenite bezel for a Stromberg-Carlson 320-T
Its pretty basic but seems to be OK.
[Image: https://www.dropbox.com/s/rj94ztrcghjasn....jpg?raw=1]
hello promocom,
Nice job myself I use fusion 360 alot !
Bob I agree with you about future parts I have made a few items .
Eico 232 VTVM Schematic
There are currently 9385 online users. [Complete List]
» 2 Member(s) | 9383 Guest(s)
