46-1209 schematic/values question
I e begun recapping and checking for out of value resistors in a 46--1209. The schematic (found on nostalgia air) gives the mf value of the capacitors but does not specify voltage. Likewise the value of resistors in ohms is given but not the wattage.
How do I determine proper voltage rating for capacitors and what wattage for any replacement resistors?
Here's a link to the parts list in the Phorum library
https://philcoradio.com/library/download...6-1947.pdf
Replace the paper caps with 630 volt film caps. You will probably pay more for exact voltage placements, no harm in using a higher voltage.
Thank you.
Eico 232 VTVM Schematic
