Threads: 6
City: Pensacola
State, Province, Country: FL
I am trying to restore this model 80 and have removed the veneer on the dome part due to many broken and missing sections.
Now the question I have what is the best way to get the bend in the veneer to glue it to the basic structure. I was thinking of soaking it in water then clamping it until it dries.
I would appreciate some advice on this.
George
Threads: 268
Hey George this might help answer some of your cabinet question... https://philcoradio.com/phorum/showthread.php?tid=22636
Threads: 6
City: Pensacola
Thanks Terry, good to hear from you,
I must have different veneer than Steve, who is the Master of all Masters. When I try to bend the veneer, it wants to crack that's why I thought of getting it wet. Also if I use Maple instead of Walnut veneer would it change the color of the medium brown walnut classic toner on the final coat?
George
Threads: 4
City: Monteith, Ontario CA
Nobody would fault you for buying a "backed" veneer (easiest and cheapest is paperbacked). It's way easier to install, doesn't suffer the same resistance to bending or tendency to crack that raw veneer does and over the arch nobody will ever know what you used.
Threads: 6
City: Pensacola
Thanks John
I will look into that. I had a thought of using maple because the walnut was on backorder, but that will not work. I will wait for the walnut.
George
Threads: 54
The cabinet on my model 81 looks like it may have been maple or birch under the finish, it's obviously not a higher quality hardwood but looks acceptable. You could always go overboard but the models 80 and 81 were entry level sets, pretty much like a later AC/DC set but with a power transformer, so they cut corners wherever it made sense to.
Threads: 6
City: Pensacola
Arran,
Thanks for the info. I have some maple, but it doesn't seem to have a lot of grain like walnut. I am also thinking of trying to put new veneer on the front which I have never attempted. Not sure I have the talent for that, but that's how you learn.
George
Threads: 6
City: Pensacola
Threads: 11
City: Greenlawn
State, Province, Country: NY
Considering what the "before" must have looked like, this is turning out nice!!
Threads: 6
City: Pensacola
Thanks for the comment Mr Fixr55,
Should have taken some before pics, it was pretty bad. Still would like to learn how to replace front with new veneer and do the cut outs for the speaker and controls.
Thats the way it is for now.
Threads: 29
City: Wellborn Florida
Threads: 110
City: Omak
State, Province, Country: WA
Hello George,
that turned out really nice !
Threads: 6
City: Pensacola
Davis and Richard, thanks for the kind remarks.
George
Threads: 110
City: Omak
Hello George,
you, welcome and man I have a real basket case that also has a messed up cabinet my veener is a mess mine is a model 89 if I remember but cabinet even had wood filler where someone has tried make it better .
Threads: 4
Nice job on the arch veneer - well done!
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
