Philco 38-690 restoration completed
Threads: 7
After more than a year - it is finished now.
Grill cloth is somewhat loose - I'll change that in the future.
It was:
[attachment=2]
[attachment=1]
It is now:
[attachment=0]
More pictures will follow.
I tried to keep it as authentic, as possible, so kept part of the original finish and grill cloth.
It was also electronically restored.
Works perfectly. "Magnetic tuning" is fantastic. A lot of stations, big sound.
Threads: 7
[attachment=2]
[attachment=1]
[attachment=0]
Threads: 24
Mighty fine piece of work there. Inspiring the rest of us.
Threads: 41
City: Shepherdsville, KY
All I can say is " WOW" a fine looking radio. Joe
Threads: 92
City: Clayton, NC
Threads: 24
City: Gladwin, MI
Very nice job! Just beautiful!
I have a 38-690 to restore also! I think it is going to be quite a while before I get it done. I'm looking for some of the old Philco paper caps for this radio suitable for re-stuffing, as some of the paper caps in my set had already been replaced by the time I got it.
If you have any from your set that you will not be re-stuffing, please let me know. You can find a list of the caps I'm missing in this thread.
Link has expired - no longer available
Ed
Threads: 7
Ed, nothing has left. I re-stuffed all paper caps in power supply chassis, even if part of them were good. As a matter of fact I saw a bunch of paper caps being sold on e-bay now. OK, it is German E-bay: http://cgi.ebay.de/320663200718
Threads: 24
City: Gladwin, MI
OK, thanks anyway. I will keep looking.
Ed
Beautiful job! One of my all time favorite radios. I tried to get one under the radar from an auction in Ohio about two weeks ago. I participated in the auction by phone along with another person from Pa. who also called in. Needless to say i didn't win. I think i may have been beaten by Willie, seeing how he just sold another one on E-bay. Oh well i will just have to keep looking.
Mike
Threads: 103
City: Calgary, AB, CA
Now that IS a very nice radio ,,you did a good job .. The photos are also very good.. We all like to see good photos of the radios. It looks like a skyscraper, and the finish is stunning.ONCE AGAIN real nice
Living in Calgary Alberta
Threads: 72
City: Linn Creek, MO
Absolutely beautiful!
M R Radios C M Tubes
Threads: 55
City: Lexington, KY
The 38-690 is an impressive radio and yours is perhaps the best example I have seen. Very good work and thanks for sharing!
Threads: 3
If I can get mine looking haft as good as yours, I'll be happy.
Thanks for sharing.
Mark
Threads: 18
Very nice indeed. An inspiration to all.
Yes...very, very nice!
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 9806 online users. [Complete List] » 1 Member(s) | 9805 Guest(s)
