Philco model 42-380 lost cap connection
Hi Everyone
Hope someone can help me with this problem. I bought this Philco radio 42-380 and upon removing it discoverd that One of the caps was only attached at one end. And even after downloading the schematic I don't understand where it connects on the other side. It is the .0015 cap. one side is connected at tube # 41 post but can't figuire out where other end connects. Looks like it may connect to red coated wire that comes off 5 w voice coil, but I am not sure . I plan on recapping completely. Can anyone tell me where it goes.
I have restored 3 other radios and have always just replaced one at a time so I don't have this problem.
Thank you
Bob
Yes - there is a .0015 uF cap (56) connected from the plate of one 41 tube to the plate of the other 41 tube. Pin 2 of each 41 tube socket.
Plate to plate capacitor make it a 1000 vdc (or more) type. Someone probably clipped it out when it shorted. It's there to tame oscillations and cancel harmonics above the audible range. A 1 KV ceramic is OK and keep the lead dress as tight as possible.
Thank you for your replies both were very helpful. Sure didn't want to guess where it went.
Thank YOU!
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 6896 online users. [Complete List]
» 1 Member(s) | 6895 Guest(s)
