Philco phonograph part number
Does anyone know what brand and part number was used for the phonograph in a Philco 41-604p?
Thank You
Tom
Hi Tom and welcome,
To answer your question I don't but here's the service info for it: https://philcoradio.com/library/download...20Book.pdf
It sez in the radio section that the phono info is on pg 135 so there it is. Pretty sure Philco made that one.
