Threads: 113
City: The Villages
I'm working on a 48-482 and I've run into a problem. The only schematic I have been able to find shows a 6SQ7 as the first audio even though all sets have a 7B6 in its place. I have a tube diagram for the 7B6 but it would sure be a help if I had a schematic that shows the 7B6.
Does anyone know where I can get one?
Eric
BTW. The problem is: squeal like feedback when turning up the treble control and with a long wire antenna I can only get one local station all over the dial. Has been re-caped. Tubes and resistors replaced as nec.
Eric
The Villages, FL
(This post was last modified: 12-10-2012, 07:05 PM by Eric Adams.)
Threads: 18
Schematic here
http://www.nostalgiaair.org/PagesByModel...013637.pdf
Tube data here for 6SQ7, 7B6 and anything else you wish.
http://www.nj7p.org/Common/Tube/SQL/Tube...?Type=6sq7
Both tubes do the same thing, and often whatever was available was used in production and changes were not always documented.
Threads: 113
City: The Villages
Thanks Codefox1, The schematic is the same as I have but the tube digrams are much clearer. Everything checks out at the 7B6. I guess it's back to the trouble shooting guide.
Eric
The Villages, FL
Threads: 4
City: Sullivan, MO
There is a factory service manual for this model on this page although it also shows the 6SQ7. It is in DJVU format so you will need a reader.
http://www.audiophool.com/Philco.html
Sean
WØKPX
(This post was last modified: 12-11-2012, 10:35 AM by Sean.)
Threads: 113
City: The Villages
Thanks Sean, that's the info I have now. I'm looking for something that shows the 7B6.
Eric
Eric
The Villages, FL
Threads: 40
City: Las Vegas, NV
Eric, AFAIK all the published prints show the 6SQ7, but the only difference is the pin numbers. That said, this weekend when I have some time, I'll pull a working chassis and take some voltage and resistance measurements. Maybe we can pin down the problem that way.
John
Las Vegas, NV USA
Threads: 113
City: The Villages
Thanks John, hope to hear from you soon.
Eric
Eric
The Villages, FL
Threads: 3
City: Eagle River
State, Province, Country: Wisconsin
6SQ7
https://www.nj7p.info/Tubes/SQL/Tube_que...?Type=6sq7
If this link above doesn't work, go directly to NJ7P's website and enter the tube your looking for
Tube Database Website:
https://www.nj7p.info/Tubes/SQL/Tube.php
Threads: 154
City: Westland, MI
The schematic in the Philco Radio Library accessed at the bottom of the Home page shows the 7B6.
https://philcoradio.com/library/index.ph...year-book/
Take care and BE HEALTHY! Gary
Thought I'd point it out, even though the thread is 11 years old!
EagleRiverMike,
Welcome.
I use Bill's (NJ7P) SQL tube database query all the time - it's much easier than getting out one of my tube manuals.
But I should mention this thread is 11 years old, and the OP (original poster) hasn't visited here in nearly two years (I hope he's ok).
Threads: 154
City: Westland, MI
Guess Ron and I commented simultaineously! Take care and BE HEALTHY! Gary
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
Var resistor id
Var resistor id
Var resistor id
Its a Sylvania 400 oscilloscope. here is a clip of r-100. Would be nice to know the current required. Not listed in part...Martinj — 02:10 PM |
Thanks Richard. I hope you enjoy it.
Here I have created an English section on the history of radio with videos in Engl...RadioSvit — 10:23 AM |
Hello RadioSvit,
first all happy new year !
I will watch your new videos this week.
Sincerely Richardradiorich — 09:19 AM |
There are currently 9738 online users. [Complete List] » 2 Member(s) | 9736 Guest(s)
