38-116 dial
The 38-116 has a 9 inch diameter Plastic? frequency dial indicator that has broken. I am looking for the best way to re-attach it OR someone who has successfuly done this OR a replacement (PN# 27-5348.
Thanks!
Jim
If you need a replacement dial, try Mark Oppat @
http://www.oldradioparts.net/
Jerry is correct, and the quality is very good
For anyone tuning in late here, Mark's address for dial scales is:
http://www.oldradioparts.net/dials1.html
Canadian GE Model 41
Umm....you do not clean potentiometers with contact cleaner. Unless cleaning the carbon layer of the base is the goal. Y...morzh — 05:52 PM
I got the tube tested and it was TU. I have installed a replacement tube. During this last effort I discovered part of...Mtmattking — 04:01 PM
Restoring Philco 96
I opened up and lubed the volume pot. It is suposed to be 500K (no one expects it to be that), and it is about 1.5M. T...morzh — 03:34 PM
Compatible crts
The 5JP1 sounds like either like a military tube, or one built for some piece of older industrial equipment.Arran — 02:59 PM
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 2254 online users. [Complete List]
» 3 Member(s) | 2251 Guest(s)
