What model???
Please look at the attached pics.
does anyone know the Model # for this Philco? I can't find it in Ron's "Philco Radio 1928-1942" bible.
Thank you
Don
39-6  https://philcoradio.com/library/download...20Book.pdf
Also see our gallery info….
https://philcoradio.com/gallery2/1939a/#...ed_variant
Looks like 39-6.
This one has different from what I have, meaning the grillwork, otherwise exact same.
They are listed together with 39-7, the latter having the preset buttons.
Thanks, guys
