Model 20 speaker rebuild
Hello all,
I've been looking all over the place and I can't seem to find any data on the inductance value for the field coil in the speaker. I have an RLC bridge but according to my ohm meter, the winding is no longer continuous. The speaker itself is beyond repair. I want to replace it but I need the inductance value for an equivalent value choke.
Thanks to all who can help!
Mike
Hi and welcome to the Phourm!
Don't know if I've ever seen the inductance measurement listed for a field coil. It should be but the norm is resistance. The resistance is important as it will determine the voltage drop a cross the coil. This can be critical if the field coil is in the negative leg of the power supply because it will determine the amount of bias voltage the power supply will develop. The model 20 it's in the positive leg.
Noting the size of the filters I'd take a guess and say between 5 and 10 Henries. Don't think it is really critical.
Hi,
Using a BK Precision Model 875A LCR meter - it reads 3540 ohms resistance and 37.4 henrys inductance when connected at the plug for a Philco Model 20 speaker at the field coil connections. It has read pretty close on choke coils that I have measured that had a published value.
Tom
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 4866 online users. [Complete List]
» 4 Member(s) | 4862 Guest(s)
AvatarAvatarAvatarAvatar
