RCA Model M101 M104 M108 auto radio 1934
First let me say that the passing of Ron Ramirez was noted with sadness on the website of the New Zealand Vintage Radio Society. R.I.P. Ron
I have come across an RCA Model 101 104 108 auto radio.I have been able to identify it thanks to info gleaned from the Phorum . Thanks everyone.It has been modified and a speaker box grafted onto the front. Does anyone know where I can see a photo of it as original? Also  was this set an aftermarket model or was it a set installed in particular makes of car?  Any help appreciated. Thanks everyone.
Some links that I hope will help. Good luck David  https://www.radiomuseum.org/r/rca_m101.html       https://www.retroradioshop.com/pages/ide...rca-victor        http://www.rfcafe.com/references/radio-c...e-1935.htm
