Philco 42-380 antenna hookups?
There are four screws on the back to run the 3 antenna wires to.  Two of the wires are paired together, the third one is not.  Question: Which wire goes where?  Looking at this model on the net, people have it connected in different ways.  Looking from the back, I have seen the two paired ones connected in the middle, then others to the left, others to the right.  Help!  Icon_crazy
Typically one is GND, one is balanced (2 wires) and one is unbalanced (single ended).
That information doesn't address my problem as the connections are not marked, and as stated I have seen different combinations hookups on the net. They all can't be correct. Just need to know what antenna wires go to which screw.
Your set the screw terminals connect only to the loop ants barring the one test point. You need the external ant adapter. It plugs into the socket above the terminal strip. It has a connection for a single wire ant.
Pulls in stations, so no additional ant required. Just need correct wire hookup sequence.
Thx
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9571 online users. [Complete List]
» 2 Member(s) | 9569 Guest(s)
