Threads: 2
City: Lake Jackson
State, Province, Country: Texas
Restoring this unit, and finally found the Code 123 documentation. Question: C4 temp comp. Fixed trimmer is 13 picofarad, as the change indicates. Is this a tubular mica of some sort, and do I really need to replace it? Same question for C6, 47 pF on the 50C5 tube.
For these types of radios, I always replace all wax caps and resistors.
This is my first post on this group. THANKS MUCH
Mark
Threads: 573
You do not replace ceramic or mica caps, unless you have some reason to believe they are bad.
Threads: 2
City: Lake Jackson
Thanks much! I suppose, because of the stated values in pF, that they are mica?
Mark
Threads: 573
If tubular (an empty small cylinder) - they are likely ceramic. A photo would help.
Mica caps are typically rectangular, while ceramic can be anything, disc, rectangular and tubular.
(strictly speaking, mica are ceramic caps, but usually they stand apart)
