Philco 370LZ chair side not a 71LZ
Big Grin
What do you guys think is the max I should pay for this??  Always wanted a chair side radio.
Philco's
86 Low Boy     71B      42-321T
90 High Boy    52B      46-1203
95 High Boy    118B     48-214
112X Console     60B       48-206
118X Console     84B       49-506
41-608P Console   610B   76 High Boy
41-265 Console   37-89B   370LZ
52GC                38-35B
20 Baby Grand   38-10T
70 Baby Grand   41-221CI
Are you sure that it is a model 71LZ and not the previous years' 370 Lazyboy? Production for both models appears to be 16,285, not common but not rare either. I generally try to pay as little as possible since the chassis is unknown so would try not to go above $125, maybe $150 at the top end since you want a chairside, there are others out there. Part of the beaded molding is missing, so inspect for other cabinet issues.
He only wants 40 so I think I’ll have to buy it
Philco's
52GC                38-35B
Just took a closer look at it.  It is a 370LZ not the 71LZ.
Philco's
52GC                38-35B
If he only wants $40.00 what are you doing still pondering over it? Go get it! Take care and BE HEALTHY! Gary
lol not pondering it’s been mine for at least an hour now ?.  At a local car show with my Jeep will load it up and take it home soon then I’ll post a few more pictures
Philco's
52GC                38-35B
That sounds like a reasonable price, to most people it's just an old fashioned end table, apparently the cabinet was styled by Norman Bel Geddes, not that the name means much these days. Nothing wrong with a 370 Lazyboy, as long as the autodyne oscillator doesn't cause problems
So had time to go through it tonight. It is a 370LZ not the 71LZ.  Other than a few scratches and a couple missing cylinder trim pieces, the bottom edges of the veneer on both sides have come lose but none of it is missing.  The chassis appears not to have been worked on at all and it’s very clean.
Philco's
52GC                38-35B
I'll mention a couple of fine points on the 370 that are different from the 70/70B that you currently have. The major thing is that the vol/off-on and tuning are on two concentric shafts. The original vol/off-on control is made out of unobtanium. A single resistor and pot combo (sold as a replacement) doesn't really preform same way the dual pot does.
The dial and drive has a couple of pot metal gears. Haven't seen any failures but I have seen some swelling which makes the tuning knob hard to turn. There's an easy fix which is to slightly enlarge the hole in the gear on the dial.
Your a mechanical kinda guy and I just wanted to give you a little heads up before you dive in. Oh for autodyne detector hater this set doesn't use a single tube mixer like the 80,84,89,19, and so on. It has a 24A mixer/27 lo.
https://philcoradio.com/library/download...n%2057.pdf
Thanks for the info Terry.  Luckily for me there appears to be no swelling in the pot metal gear it rotates the tunner easily
Philco's
52GC                38-35B
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
