Philco 84 antenna connection
Hello Everyone,
I was wondering what was the best way to connect an antenna for testing on my Philco 84. The field coil was bad and I found a replacement. I have never connnected these old sets up but see that there is an antenna and ground lug. I am not sure of the the wire type, loop arrangement, etc.
Regards,
Bob
I've used a single long wire up as high as possible and away obstacles. The gnd can be connected to a copper water pipe if your domicile doesn't use pvc pipe. Don't know that a loop would work very well w/this sell as it doesn't have a lot of gain.
From where I am I can pick stations up in CA and down in the Carolinas w/o a problem.
Very simply connect al long piece of wire to that contact for your antenna.   A piece 10 to plus 50 feet is no issue depending on the strength of the stations in your area.
Philco's
86 Low Boy     71B      42-321T
90 High Boy    52B      46-1203
95 High Boy    118B     48-214
112X Console     60B       48-206
118X Console     84B       49-506
41-608P Console   610B   76 High Boy
41-265 Console   37-89B   370LZ
52GC                38-35B
20 Baby Grand   38-10T
70 Baby Grand   41-221CI
Have a Philco 80 my long wire is app 30 feet, for a ground in my work shop have a ground rod that is used only for radios. If you installed a ground rod for your radios make sure it is 15 feet or more from the ground for the house electric. Enjoy your Philco 84. David
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 5611 online users. [Complete List]
» 1 Member(s) | 5610 Guest(s)
