Philco 96 Dial Re-Stringing Help
I have a Philco 96 with a broken dial string. I am not sure how to restring this radio. I assume you start with the tuning condenser fully closed, but cannot find any diagrams for how to route the cord and where to take 1 1/2 to 2 1/2 cord wraps for allowing the dial cord to grip. There is one spring in the dial drum for tension. Any help in how to route and wrap the cord for this radio would be appreciated.
Charles
