model 41-280 no stations or sound
I'm in the process of restoring a console model 41-280. I have a replaced the caps, the power cord, and verified the tubes and speaker are ok. I felt my next step should be to check tube voltage and this is the results: 41 output tubes read 160 and schematic says 175. Didn't check the 7c6 audio as the schematic dosen't give any value on voltage. Both 7b7 tubes read 158 versus 180 on the schematic. Finally the xxl tubes read 66 and 31 versus 95 and 40 on the schematic. My questions are are these readings acceptable and am I going about this in the right manner. This is my first attempt in restoring a vintage radio as you can probably tell. Any comments will be appreciated. Bill
Follow the B+ line and voltage divider resistors. One or more have most gone way up in value. When in doubt, replace. Cheap enough. Your voltage readings should be at or slightly above nominal values.
Schematic here
http://www.nostalgiaair.org/PagesByModel...013415.pdf
Thanks for the reply but I guess I don't know what the B+ means.
No problem, start at the cathode of the 84 rectifier (pin4) with respect to the chassis. This is the B+ supply. Trace the path after the field coil and measure voltages as indicated on the schematic as the resistors further divide the supply. Hopefully you can then isolate the problem to a certain section.
Thanks, I'll do that.
Would anyone out there know what the plate voltage should be on the 84 rectifier and 7c6 audio tube for a 41-280. I don't see anything on the schematic for these 2 tubes. Also is there a + or - factor on plate voltage? Thanks, Bill
I've got a better question. What is the resistance of the plate resistor on the 7C6. Should be 220K is it? I'll take a guess and say about 75v.
The plate voltage on the 84 isn't that important as the set is making HV and is close to spec.
B+ is another way of saying high voltage. Goes back to the old days (1920's) when sets used batteries. A battery supplied the filament voltage, B battery supplied the high voltage and the C battery supplied the negative bias voltage for the audio stages. So B+ is a reference to the + side of the high voltage.
Hi Terry, The reading I got on the 7c6 is 96 but I get a 87 reading on this same tube in another set I have and it works perfectly. Now can you tell me what's wrong and what my next step should be? Thanks, Bill
Ok Voltage seems good. When you say no sound do you mean there is absolutely no sound if not what do you hear?
Just a faint humm and no speaker cracking when you turn the band selector.
Measure the voltages on each 41 tube. Pins 2,3,and 4 to chassis report back
The 41 nearest the 84 tube readings are 166,158 and 5.5( speaker cracks when touching this post) The very back 41 reads 165,168 and 5.2
Ok that all good. On the 7C6 if you touch pin 3 with your finger it should buzz good and loud. does it?
Terry, I get nothing at all.
Hmmmmm
Well there one problem. Is the 7C6 lit? Can you see the filament glowing? Do you have an audio signal source like a fm tuner, tape deck or something?
Should be a cap connected to pin3 (the plate of 7C6) over to the control grid of one of the 41's(pin4) Is it there?
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
42-345 Resistors
Great comments. I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM
