Twist Lock Style Solder Tabs
Threads: 14
City: Tulsa
Does anyone know what you might call those solder tabs on vintage electrolytic capacitors? The kind of tabs that fit through slots on a chassis, and then you would twist them to structurally lock the capacitor in place while also electrically connecting to the chassis ground? I do not know what to search for in order to buy any connectors like this.
Joseph
Philco 46-480
Philco 49-906
Threads: 43
City: Roseville, MN
Are you referring to the phenolic wafer that they are sometimes mounted on? If so you would have to provide a diameter measurement.
Threads: 562
They are called just that, twist-lock tabs.
They are not mount on the phenolic plate. They are always protrusions of a solderable metal ring that is pressed into the aluminum case.
Now if you are trying to make somethfhing instead of them, by soldering them onto you PCB, well, you could just look for QC (quick connect) tabs, smaller gauge, and use them to solder to the PCB, and then put them through slots in tthat phenolic base and twist them. Or through slots in the chassis.
https://www.mouser.com/c/connectors/term...Disconnect
You can use these, and for twisting cut a notch on either side.
Threads: 14
City: Tulsa
No, not the wafer. I’m referring to the metal tabs on the capacitor itself which provide an electrical connection as well as holding the capacitor in place.
I’ve seen some capacitors with these tabs passing through slots on a phenolic wafer, and other times I’ve seen them pass through slots on the chassis itself. Here’s a photo of the chassis which this particular capacitor came from.
Joseph
Philco 46-480
Philco 49-906
Threads: 14
City: Tulsa
Ah-ha, thank you Mike! Let me do a bit of research here. Yes, I’m trying to design a PCB substitute for that capacitor.
Joseph
Philco 46-480
Philco 49-906
Threads: 562
Dunno if you saw it; you answered before I appended the link to that post.
This said, I successfully (and other folks too) disassembled and restuffed twistlock caps, at least 10 of them. If you carfull within reason, you simply reuse everything.
Threads: 14
City: Tulsa
These QC connectors are exactly what I am looking for. There are a range of useful styles.
Joseph
Philco 46-480
Philco 49-906
Threads: 14
City: Tulsa
And thank you for adding the link. Yes, we are certainly posting responses back to back!
Joseph
Philco 46-480
Philco 49-906
Threads: 562
If using solder-tine type, use flat, not round. This will make harder for it to spin in the solder hole.
Threads: 14
City: Tulsa
Great advice!
Joseph
Philco 46-480
Philco 49-906
Threads: 562
Also, some of them are thin. You want some thicker one, as thin, when twisted, will not hold the cap tight. The idea is to get something reallhy close to the slot size. They should not twist easily, they should offer some resistance when twisted.
Threads: 54
There is a sort P.C board substitute for twist lock cans called an "Adapt-a-cap", but I think that they are overpriced, and not really fit for purpose since they are using through hole solder pads on a P.C board for not only connecting the capacitors but connecting the wiring. I think that the method that Mike, and others use with restuffing the original can is more economical, and mechanically stronger then just tacking wires onto a disk of P.C board. It's like they didn't take into account that in vintage radios and TVs the base of these capacitor cans was also used as a terminal strip, not only for the capacitors but the ground lugs were used for other parts. If they really wanted to make the adapt a cap useful then instead of making it just a glorified P.C board they should make it like a terminal strip that fits over the hole in the chassis, but one in which you can put a can on top of to cover the radial lead electrolytics above the chassis. I don't think they even make one that fits in the way that one does on your Philco chassis, where the hole is punched to accept the ground tabs from the can, their are more like a copy of the diamond shaped mounting plates that would be riveted onto the chassis. They also have the same issue in that you have to remove the old can from the chassis, as you may or may not have to do with restuffing, along with disconnecting the wiring under the chassis.
(This post was last modified: 01-09-2025, 11:25 PM by Arran.)
Threads: 14
City: Tulsa
Agreed, Arran.
I’ve got an idea in mind. I plan to design a PCB with the footprint of the old capacitor. I’ll solder the new caps into through-hole mounts on the PCB, and their pins will route to PCB mounted solder lugs for the wiring connections under the chassis. Finally, I’ll use some of these QC connectors for the twist lock connections to chassis ground. I feel that this design will be pretty robust.
I could restuff the existing caps, yes. However, I’m up to the challenge of engineering a modern-day solution. Challenge accepted!
Joseph
Philco 46-480
Philco 49-906
Threads: 110
City: Omak
State, Province, Country: WA
Hello joseph,
Sounds great I love using the autocad suite of software like the fusion 360 and tinkercad .
I have designed a few circuit boards and had PCB way make them for me .
Threads: 54
Joseph;
I think that there may be a market for something like this, it would certainly be an improvement over those Adapt-a-cap things. Since I found out how much it costs to make something like those through an outfit like PCBway I don't know why anyone would pay $5 on up for one. Granted they are cheaper then a Heyseed Hamfest unit. but at least those are largely drop in replacements (I would like to know what capacitors they use inside good name brand or Chinese mystery brand?). One alternative I have also used was to mount a terminal strip under the chassis, on one of the lugs of the original can, or to one side of it, if there is room for it, leaving the original appearance above the chassis.
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
Var resistor id
Var resistor id
Var resistor id
Its a Sylvania 400 oscilloscope. here is a clip of r-100. Would be nice to know the current required. Not listed in part...Martinj — 02:10 PM |
Thanks Richard. I hope you enjoy it.
Here I have created an English section on the history of radio with videos in Engl...RadioSvit — 10:23 AM |
Hello RadioSvit,
first all happy new year !
I will watch your new videos this week.
Sincerely Richardradiorich — 09:19 AM |
There are currently 5047 online users. [Complete List] » 1 Member(s) | 5046 Guest(s)
