Philco 91 Restore Code ??
#46
Because the usable power rating of it then is (3,200/20,000)*25W= 4W.
Maybe a tad more due to the mass, but not much. You are not using the full resistor.
#47
I wondered about that. Wish there was some place local to get this stuff.
The speaker table error?
Philco 70 antenna lead
There are currently 6318 online users. [Complete List]
» 1 Member(s) | 6317 Guest(s)
