Philco 46 done at last
First pics are the finished ones. Following pics are the "before" ones.
http://s1194.photobucket.com/albums/aa37...ilco%2046/
There are currently 9349 online users. [Complete List]
» 2 Member(s) | 9347 Guest(s)
