48-360 color
Was a toner used on the 48- 360?
Hard to tell. I would guess that clear lacquer was sprayed over the plain wood, since there is no visible tinting of the wood.
Thanks Ron
I will just use clear .
There are currently 10475 online users. [Complete List]
» 2 Member(s) | 10473 Guest(s)
