46-200 brought back to life
I'll keep looking for the correct speaker but otherwise she's done.
Before:
[Image: http://i863.photobucket.com/albums/ab191...-200-3.jpg]
After:
[Image: http://i863.photobucket.com/albums/ab191...-200-8.jpg]
Larry
Nice!
I have a 46-200 that looks like it had been drop-kicked Icon_lol but it
works very well!
Rob
There are currently 10322 online users. [Complete List]
» 1 Member(s) | 10321 Guest(s)
