Philco 90 - Which Version?
francois8890 Wrote:......If not the correct grille cloth can you tell me which one of John's products is the correct one? It looks like maybe #1 or #2 in his online catalog.
It's hard to tell from the picture, but your cloth looks like a generic pattern sold on eBay:
http://cgi.ebay.com/300559988740
If that is your cloth then pick up some #1 from grillecloth.com as already suggested.
And congratulations on your new 90!
Yes Ron, That was what I was looking for initially although I got a little conflicted there when I was studying it thinking I might want the late version but the price coupled with the overall good condition convinced me to go ahead with this one.
I have a piece of the #1 grille cloth from John that I was going to put in my Zenith 10S130 but I may order the #2 and use for it instead if the #1 is correct for the 90.
Since I am going to probably be displaying bot of those sets pretty close to each other I would rather that the grill cloth not be identical on both sets.
thanks,
Frank
Wow Frank...that is one beautiful radio!
There are currently 9837 online users. [Complete List]
» 2 Member(s) | 9835 Guest(s)
