Model 87 Audio input xformer and output xformer to 45 tubes
Does anyone know the impedances of these transformers or a way to calculate it from a tube manual ? I see many transformers available and might work but they are too expensive to play hit and miss.
Thanks
Jim
Hi Jim,
If it is the trans #25 connecting between the first AF 226 and the second AF 245's you can use the Hammond HX124A from Radio Daze. I used it on mine and it works great. Hope this helps,
Richard
Richard:
Thank You ! Half my battle is over. That was exactly the transformer I was considering but unsure until you verified it.
Now I am chasing down tou output transformer from the plates of the 45's to the speaker. One side of the primary is open. I was considering the Hamond P-T1615.
Jim
Jim, You are talking about the trans on the speaker #36. If so check all the connections. I had one that had the same problem. I checked and found a bad solder connection at the trans side of the cable. I cleaned and re soldered and it worked fine. If not, I will try to get the resistance of the trans for you to match.
Richard
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
42-345 Resistors
Great comments. I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM
