Wanting information about the value of a Philco tweeter
I've never used this forum before ... but here goes: Does anyone have any feedback, general information, or expertise about a Philco tweeter made in Japan (perhaps as much as 3- years ago or more) model 36-1703-1? I would greatly appreciate hearing from you.
Nickolas
Philco tweeter ... made in japan ... 3 years ago or so
maybe if you have a picture it would make more sense...
-Mars
There are currently 8858 online users. [Complete List]
» 3 Member(s) | 8855 Guest(s)
