Threads: 17
City: Yorkville IL
Good Afternoon..
Well it's time to begin the Philco 118 Highboy I acquired from a phellow phorum member. Attached are a couple of pictures. As I dig into it I may have some questions. the first one I have is, the long WW resistor in the picture of the underside of the chassis is bad (it's number 60 on the schematic). What should the watt rating being for this 6500 ohm resistor? Would 7 Watts be big enough? I ordered the 40 gauge wire for the shadowmeter so when that arrives I'll work on that as well. Does anyone have a closeup of the shadow meter light bulb socket? This one seems to be broke and bent up, I just need to know what to look for  I am also in the market for a scrap electrolytic cap to fill the whole in the left rear corner it's 1 1/4 to 1 3/8 in diameter.
This should be fun..
Glenn
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
Threads: 50
City: Apple Creek
State, Province, Country: Ohio
Glenn,
I have a couple caps the size your looking for on their way to me. I bought them for my 71 but then found some Mershon caps for it. Once I get the caps i'll shoot you a pic of them, if you want one you can have it for postage.
Threads: 17
City: Yorkville IL
That would be great!! Thanks Keith, just let me know.
Threads: 18
I'd use a 20 watt resistor there. It;s going to get warm. Would be great if you can find one like the original and then you can use the same mountings. Have a look and make sure there are no issues with the field coil winding.
Threads: 17
City: Yorkville IL
Good call. I'll check that when I get home. Finding a direct replacement may be difficult. I found 6800 ohm replacements at Mouser buy I think the biggest they sell is a 13 watt unit.
Threads: 92
City: Clayton, NC
Hello, Glenn: dumb question, but is it bad?
Have you tried Play Things of the Past for your resistor?
RS Electronics has a 25 watt power resistor that adjusts from 1 ohm to 25K ohms. You adjust the slider on the resistor and when you have it at the value you want, you tighten the slider so that is is in effec a "fixed" resistance.
http://www.rselectronics.com/Catalog/Sea...44&HT=1314
Threads: 17
City: Yorkville IL
TA Forbes Wrote:Hello, Glenn: dumb question, but is it bad?
Hey Tom,
The resistor is bottom center in the 2nd picture. It's supposed to be wirewound over the complete length. It's crumbled. I will try PTOTP, and if not then the link you sent is an option, I would like to keep it as original as possible.
Glenn
Threads: 54
That's no good anyhow, they have a minimum quantity on most of their parts. Try Mouser they seem to have ones that are close:
http://ca.mouser.com/Passive-Components/...j&SAP=true
P.S Why do they have a shunt from B+ to ground? Something like that between B- and the chassis makes sense? Is this related to the shadow meter?
Threads: 17
City: Yorkville IL
I ordered the 7k 20 watt resistor from Mouser. I didn't need enough other items to meet the minimum order at PTOTP. Should get it and the small lytics today. Started rebuilding bakelight blocks yesterday 2 down 9 more to go.
Glenn
Threads: 54
I think that I found out what the resistor is for, it was an old fashioned means of hum reduction, how critical it is I don't know but the set would probably work without it. I think that I may end up ordering one of those 7K resitors myself, one of the wire wounds in my 3118 was open and it may have been that one rather then the one across the shadow meter, hopefully 20 watts is all it needs. Speaking of 7K I think that was the model of Philco speaker that these sets used, if it was I am in the market for one.
Threads: 17
City: Yorkville IL
Speaking of Shadow meters and shunt resistors, This chassis didn't have the 2900k shunt on the shadow meter. After looking at another picture of a 118 chassis (Thanks Ron), the location where it should be was located. However this one looked like it never had it. All the labeling is gone on so I have no idea what "code" number this was and nothing I have read indicates any production changes that would have affected this resistor being left out.
Glenn
Threads: 17
City: Yorkville IL
Hi guys,
I'm still rebuilding bakelite blocks and have a question. #72 on the schematic shows a .25 mfd single cap. it has 3 leads at 2,4,7 per the Philco service bulletin. The solder connections were pretty grimy/dirty, but it appeared there were only cap connections on numbers 2 and 4, however when I pulled it apart there were two condensers in there. One of them had very obvious leads to the top, but the other appears to not have been connected to anything. So I did some research and found out the part number, 6287-r, was changed to 6287-ODU and it shows a dual .15 Cap and different connections. On the number 7 terminal is a connecting point for resistors 67,68, and 26 also a feed to the 1 mfd elect. cap number 46.
If I configure this block with the double cap as the part number shows, that would add a cap between the filter choke number 71 and the resistors, which I would think would be incorrect. Can someone please verify this so I can continue on, this was pretty butchered in the distant past and my mind is fried at this point.
Glenn
Threads: 11
City: Black Mountain, NC
glennpr Wrote:Does anyone have a closeup of the shadow meter light bulb socket? This one seems to be broke and bent up, I just need to know what to looks for Glenn
I took photos of my meter bulb socket last night. As soon as I download in a few days I'll post them for you.
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Threads: 17
City: Yorkville IL
Thanks!!
Glenn
Threads: 11
PhilcoMike Wrote:glennpr Wrote:Does anyone have a closeup of the shadow meter light bulb socket? This one seems to be broke and bent up, I just need to know what to looks for Glenn
Mike
Glenn,
Here are three photo views of the light socket. The shadow meter has been temporarily moved out of the way in the photos. Could I offer these in trade for a front and side view of your 118H cabinet? I am needing to refinish mine.
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Milkjug plastic?
Whatever is chosen for the spider, the material must be compatible with popular adhesives...
Th...Chas — 05:05 PM |
Mike;
I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM |
This is my thread on 60 from 2016.
I had to rewind the osc coil, and I actually counted the turns and then rewound i...morzh — 03:34 PM |
Yes, Mark belongs to the same Michigan Antique Radio Club that I do. I suspect that the oscillator coil is in need of a ...Radios1340 — 03:10 PM |
Yeah. I am dreading the thought of what to do with all my consoles when I will no longer be able to move them around.
I...morzh — 02:51 PM |
Cool gadget, Buzz.
I took me a couple of second to undestand that that oscillating thing makes the wire to spool correc...morzh — 02:50 PM |
My back hurts already, you could build a house with all the wood. PaulPaul Philco322 — 02:49 PM |
Part 4 of this series now uploaded
link below to anyone interested
Buzz — 02:39 PM |
Welcome to the Phorum, Radios1340! The oscillator coil on the 60 is a common culprit. I just bought a 60B (June 1934) ...GarySP — 02:33 PM |
Yes, standard alignment procedure. I can get the minuscule tone to vary when adjusting the trimmers. But you almost have...Radios1340 — 01:40 PM |
There are currently 8108 online users. [Complete List] » 1 Member(s) | 8107 Guest(s)
