Cabnet Restroation 42-PT-93
1. What kind of wood am I dealing with?
2. What color(s) lacquers should be applied?
3. What is the correct grill cloth?
Thank you. David G. Woodward
1. Most likely, two or three different species of Walnut.
2. Medium Walnut, with black lacquer trim.
3. The correct cloth is no longer available. This pattern was closed out before the Great Grille Cloth Shortage began. Correction: Pattern 50 or 51 might work, if it is still available, that is.
Thank you.
I still have some CRC #14 and GRC #01 meterial left. Would either of them be correct? Thank you. David
There are currently 10608 online users. [Complete List]
» 4 Member(s) | 10604 Guest(s)
AvatarAvatarAvatarAvatar
