Record Changer - Model 46-1213 - Restoration Source
Any tips on who does a good job restoring the old record changers. Not sure if the 46-1213 was 78 or 33 rpm. Since it is single speed I would guess 78 rpm. Needs the usual: Cleaning and lubrication, prob a new cartridge, new IW and new stylus. Yeah, I know I am chicken. Icon_evil
http://www.west-techservices.com/
Thanks Ron. I appreciate all you do.
Thank you! Icon_smile Tell Gib I sent you.
The speaker table error?
Philco 70 antenna lead
