Need help identifying old Philco mahogany cabinet.
Today I found this old Philco mahogany cabinet at a thrift store. The model number is 10853-3 can anyone tell me what it is and what year it was made? If you need a better more detailed picture's let me know. thanks.
Michael,
That isn't a good Philco model number.
Pictures will help.
Carl
Northern Panhandle, WV
The actual model number will either be on a blue and white paper tag, glued to the inside of the cabinet and visible, or it may be black ink-stamped on the rear of the chassis with also a Code number possibly.
Pictures will help us help you.
Chuck
Pictures submitted by the OP:
[Image: http://i326.photobucket.com/albums/k420/...0007-1.jpg]
[Image: http://i326.photobucket.com/albums/k420/...0006-1.jpg]
10853 is the number of the cabinet itself. Probably later than 1949, I am guessing it would be in the 1950-52 era. Plus, from the looks of the interior, it appears that it was originally a TV-radio-phono combination before being gutted. I do not have any photos or illustrations of any Philco radios or radio-phonographs that match this cabinet.
This cabinet was like the first TV that my family had when I was a kid. We got it in 1956 (was told to be a 1950 model) - it was used and the Philco dealer installed a new picture and installed a tall external antenna all for $100.00. The TV was on the left side and the radio and record changer was on the right side as viewed from the front. When the TV failed I removed the TV and radio part. I installed a newer type changer and amp and my mother used that until she died in 2006. I still have the two doors partly because of the wood and the other because of the many hours of enjoyment that it gave me.
Tom B
Canadian GE Model 41
Umm....you do not clean potentiometers with contact cleaner. Unless cleaning the carbon layer of the base is the goal. Y...morzh — 05:52 PM
I got the tube tested and it was TU. I have installed a replacement tube. During this last effort I discovered part of...Mtmattking — 04:01 PM
Restoring Philco 96
I opened up and lubed the volume pot. It is suposed to be 500K (no one expects it to be that), and it is about 1.5M. T...morzh — 03:34 PM
Compatible crts
The 5JP1 sounds like either like a military tube, or one built for some piece of older industrial equipment.Arran — 02:59 PM
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 2262 online users. [Complete List]
» 3 Member(s) | 2259 Guest(s)
