Who can repair 39-116 and Mystery remote in Los Angeles?
Hi-
I need to have my 39-116 worked on (volume is low; remote only works within 5 feet of console) in the Los Angeles area.
Can anyone recommend a reliable repair person?
Thank you very much,
Lew
Lew:
Where in the LA area are you located? I am in Thousand Oaks and may be able to help you out with your radio. I restore antique radios and televisions and own a Philco 39-55 AM only remote and got it working pretty well.
FYI, the 39-55 is the "Little Brother" to the 39-116, so Mystery Control setups are the same.
Did you ever find a repairman knowledgeable in the workings of the Mystery Control? I have acquired one with a broken dial return spring and need possible leads to a replacement.
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4803 online users. [Complete List]
» 2 Member(s) | 4801 Guest(s)
