antena
hello i need help with wiring for my antena on a philco 37-60 what connections do i use there are four and do i have to run a ground wire? would some one please explain the process.
thank you.
tom.
Antenna coil or just to hook up for reception? The coil connections would be shown on the schematic, there should be only two for antenna conection 1 clip for the wire and 1 clip for the ground.
The speaker table error?
Philco 70 antenna lead
There are currently 6195 online users. [Complete List]
» 1 Member(s) | 6194 Guest(s)
