Texasrocker are you out there? Another cap question.
I know you have some reference which is better than that posted on the work bench. Another one of those dang philco bakelite stuff caps I can't find a reference to. Its a 3903AB. I know it has one cap in it, can you tell me what it is? Add another as an edit, the 3903T. Single cap, what is it? One more, not on the bench list, a 7025D. Any help appreciated.
Thanks Jerry
3903AB= 3903OSU
ONE ,01 UF 600V
3903T = 39030SU
ONE .01 UF 600V
SERVICE BULLETIN NO. 289
Is where I found the info
no 7025D
but
7625D
3-4 .015 uf 600v
1-5 .006 uf 600v
Thanks TROG, got me off and running again. Will have to check on the 7025D, perhaps I missread it and it was a 7625D.
Jerry
Sorry for the delay getting here Jerry. Been real busy lately. Looks like you have the specific caps info you needed now. Always glad to help if I can, you can also pm me, as I'm not on the forums each and every day.
The speaker table error?
Philco 70 antenna lead
There are currently 3384 online users. [Complete List]
» 1 Member(s) | 3383 Guest(s)
