Lubricant for Variable Capacitor
Threads: 569
What is a good lubrication for the tuning cap?
Is there something I can use that's readily available, like petroleum jelly, or does Radio Shack sell something?
Or maybe, an auto parts store?
I'd prefer something that I put in and do not touch it ever again (I am sure the old lubrication was there since the inception - but I washed the cap in the dishwasher so it got stripped off)
Threads: 268
I use a bit of white grease myself, for better or worst.
Threads: 27
City: Rochester, NY
Sewing machine type oil. Careful not to over-do.
Threads: 55
City: Evanston, IL
I use Lubriplate - a white grease.
Chuck
Threads: 40
City: Lehighton
State, Province, Country: PA
TimC Wrote:Sewing machine type oil. Careful not to over-do. Same here.
Larry
Threads: 569
Than you all guys.
I take it, no one uses WD-40?
Actually, I found yesterday "WD-40 with white grease". What do you think?
Threads: 569
There is a can of "Crisco" in my fridge. Use it to season my cast iron skillets.
It's white.
I even came up with a commercial slogan for "Crisco" (hope they see it and pay me for it):
" Crisco! Another white grease!"
PS. Went to automotive store, bought "Liquid wrench" with While Lithium Grease in it.
Worked like a charm. All squeaks and groans are gone!
Than you guys!
Threads: 18
Agee with all for once. I use a tiny dot of lithium grease applied with a toothpick and a half a drop of WD40 sprayed in it's cap and applied the same way. Of course I do this after blasting the old crud out of there with deoxit and letting it dry over night. Sewing machine or instrument oil probably just as good.
Threads: 569
codefox1 Wrote:I use a tiny dot of lithium grease applied with a toothpick and a half a drop of WD40 sprayed in it's cap and applied the same way.
Actually, there is pre-mixed WD40+White Lithium Grease sold on the same shelf with regular WD40 and the "Liquid wrench" in most hardware / automotive stores.
>>and found that the field coil is bad. Should be 1140 ohms, tests at 1.1k ohms.
You have one stringent crit...morzh — 02:07 PM |
Yes I was there. I got some real bargains there. Plus a Zenith 7G605 clipper that I have been trying to find for a fair ...Radios1340 — 01:46 PM |
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
There are currently 7218 online users. [Complete List] » 3 Member(s) | 7215 Guest(s)
