Simplex model H AC
I have owned a Simplex model H AC (circa 1931?) cathedral radio since the late 70's. Power cord is missing as well as the tubes, (3) 24's, (1) 45 and (1) 80. Front bezel surrounding tuning thumbwheel says "Clearcut", possibly a private label brand? Any info you can shed on this radio? I have photos I can email if anyone is interested. Thanks
Radioman1950
Radioman,
Check this out at the Nostalgia Air site: http://www.nostalgiaair.org/PagesByModel...018419.pdf
Hi
I've got a couple of Simplex sets myself. Simplex chassis anyway. Seems like they got renamed and rebranded alot. Here's one of them it's a little newer than your set.
http://www.flickr.com/photos/53710524@N0...hotostream
Here's the other one. http://www.flickr.com/photos/53710524@N0...hotostream
This one is up and running. Picks up station pretty well considering the low budget circuit
I was trying to get one of those little cathedrals myself. Know of one for sale, but the either the guy wants to bundle it with a crumbling console or the price keeps going up. Last time I checked the price was $200 for it and it's missing a tube. I like them and will pounce when I find a fair priced one. Icon_smile
There are currently 9698 online users. [Complete List]
» 2 Member(s) | 9696 Guest(s)
